enable msdp
enable msdp {vr vrname}
Description
Enables MSDP on a virtual router.
Syntax Description
vrname Specifies the name of the virtual router on which MSDP is being enabled or disabled. If a name is not specified, it is extracted from the current CLI context.
Default
MSDP is disabled by default.
Usage Guidelines
None.
The following command enables MSDP on a virtual router:
enable msdp
This command was first available in ExtremeXOS 12.0.
Platform Availability
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
